Jet engine render pass
  • Jet engine render pass
    Hi folks.
    I have a little issue with rendering out the jet engine phoenix preset in my exr sequence.
    Everything looks great in the VFB
    But importing it into After Effects causes some issues.
    As far as I know I have the ACESsg set in AE but still get an issue with the jet on alpha.
    In the image you can see everything looks fine in the VFB but once comped in AE it's not showing correctly.
    Any ideas as to why?
    I'm not an expert on after effects, but just by looking at the yellow color of the rocket I can tell that it's not just the jet but also the color overall is not the same suggesting that the aces is not applied correctly.
    Dmitry Vinnik
    Silhouette Images Inc.
    ShowReel:
      Hello,
      The jet engine preset is using Fully Visible fire opacity mode which doesn't have alpha. If you change the Fire Opacity mode to "Use Own Opacity" you should get proper alpha channel for the fire.
      Georgi Zhekov
      Phoenix Product Manager
      Chaos
