5.22.0 startup error?
  • 5.22.0 startup error?
    Hello, when starting 3dsmax after installing Phoenix 5.22.0 we get the following error message in the listener:
    -- MAXScript ExecuteMAXScriptScript Exception:
    -- Compile error: Unexpected end-of-script
    If I roll back to 5.20.00 the error no longer appears.
    No idea if something isn't working properly or not. It seems to work fine despite the error.
    3ds Max 2024.2
    V-Ray 6, update 2.1
    /Andreas
    Hi, thanks for posting. We have this issue reported as a bug in our internal system ( PHI-7496 ). I will add your thread to it and update the priority.
    Vladimir Krastev | chaos.com
      Any update on this issue? I installed 5.23.00 this morning and it is still there.
        Same here, just installed it on Max 2024 and getting the same error
        DAVE BUCKLEY
        www.daveandco.co.uk
          Hello,
          From our investigations the issue concerns only 3ds Max versions before 2025, it shouldn't cause any functionality loss - it will just pop up in the log, but everything should be working correctly.
          Georgi Zhekov
          Phoenix Product Manager
          Chaos
