Network rendering issue - Resimulation grids are not rendered
  • Network rendering issue - Resimulation grids are not rendered
    Max 2024
    Phoenix 5.23.00
    Ran into a minor issue.
    3 phoenix grids rendering in one scene. First 2 work fine.
    3rd works fine if using the original sim, but if Resimulation is turned on, I can render it locally but it's not visible in the network render.
    But if I load the grid into the input channel and turn Resimulation off, it renders fine.
    So for some reason, it's not loading this grid correctly on the nodes. All the nodes have access to the network storage where the sim resides, and I am using the UNC path, not a mapped drive.
    Hello,
    The Resimulation path is different than the one used by the regular sim, could it be that the network render can't access these files?
    In the Resimulation rollout - Output and Render Path is the path for writing the output cache files from Fire/Smoke resimulation. Is it using an UNC path?
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
