Rendering a pool taking an age
  • Rendering a pool taking an age
    Hi all,
    I typed this as I was doing tests and the results are making me think I should be putting this in the Corona forum instead but I'd rather have as many eyes on this as possible.
    I've simulated an infinity pool and it ran with no issues at all.
    However, it's taking ages to render.
    Some info:
    Using Max 2025 and the latest version of Corona and Phoenix.
    Doing a 1920x1080 test down to 6% noise
    The material I'm using for the water is one we've used multiple times in the past with no issue.
    Pool ON with splash & foam ON = 20mins to get to pass 5 - 1hr 56min estimate remaining
    Pool ON with splash & foam OFF = 10mins to get to pass 5 - 58min estimate remaining
    ​Pool OFF = 2mins to get to pass 5 - 10min estimate remaining
    Putting a default corona physical material on the pool
    Pool ON with splash & foam ON = 2mins to get to pass 5 - 3min estimate remaining
    Setting the material to water using the preset
    Pool ON with splash & foam ON = 5mins to get to pass 5 - 25min estimate remaining
    I tried this pool (just the phoenix stuff) in a job from a year ago and it renders absolutely fine even with using the material that was taking 1-2hrs to render.
    The only other difference is that we used to work in meter scale, we've now moved to cm - simulating (phoenix & tyflow) work much better in cm I find.
    However, I created the following and did some interactive tests:
    1. A blank cm scene & merged in this pool
      • it was taking quite a while to get a good interactive render
      • putting more opaque materials on the pool sped things up
    2. A blank meter scene & merged in this pool
      • I had no issue with rendering this at all.
    Does anyone have any idea what could be the cause of this issue?
    I'm relieved that it doesn't actually seem to be the Phoenix sim but that doesn't help me because of the rendering issue.
    Thanks
    Hi, this could be many things. I would bet on some issue with one of the materials or some Phoenix setting. The best thing you can do is submit a support ticket here (with Corona selected as the product, please also state which exact version number of Corona and Phoenix you are using!) and our team will investigate: https://support.chaos.com/hc/en-us/requests/new
