volcano help?
  • volcano help?
    hi,
    I 'm trying to simulate a volcano heavy smoke ,
    I 'm trying to tweak the rocket example,
    but the smoke just go straight...
    how can it draw a sort of cone???? do i need to use spacewarp? a drag one?
    regards
    I'd say Pressure Decay does just that. Essentially it will lower the Pressure the higher the smoke is. Also used for nuke like effects as far as i remember.
    quote from the help
    Pressure decay (MXS: pressdec) - In the real atmosphere the higher we are the lower the pressure is. For small scale simulations the effect is negligible, but for large scale simulations (like nuclear explosion) it plays a very important role. The quantity of this parameter is just a multiplier - value of 1 means a pressure decay as in the real earth atmosphere.
    Regards,
    Thorsten
      yes the pressure decay is added for such reasons. as additional factor the turbulence is important too.
      ______________________________________________
      VRScans developer
        thank you both,
        I was a bit shy increasing the pressure decay to 0.5 or 1
        but a value of 900 gives me good results !!!!
        regards
          I think it is scale dependent. Maybe ur sim cage just small in 3dsmax units
          I just can't seem to trust myself
          So what chance does that leave, for anyone else?
          CG Artist
            yes that's right...about 60x60x60 unit 1unit=20cm....
              you can increase the scale, or set some pressure decay multiplier.
              VRScans developer
                i just made a small test
                VRScans developer
