Resetting the Simulator?
  • Resetting the Simulator?
    i am just testing a water simulation. sometimes when i want to change the object which emmits the water, the simulation ignores the changes an emmits the water at the old position. so i have to delete it a generates a new one. is there a possibility to reset the simulator?
    Thanks a lot,
    Oliver
    how you change the object, by hand or it's animated?
    ______________________________________________
    VRScans developer
      By hand. I just changes the position or the shape of the object.
        ok, i will try to reproduce it
        VRScans developer
          For example: i take a plane as source and set a few polygones as emitter (via polygone IDs). Changing these IDs could produce the strange behavior (sometimes not!). If it happens again i send you a screenshot...
          Oliver
