Hi everyone.
I use Phoenix for liquid simulations for about one month, and I still have many problems.
I read many of problems on this forum, and found out some new informations.
I had a problem of boiling water surface and found solution to use Classic advection (I used FT), but now I have even more problems, as you can see od those clips:
Here you can see water flow for about 5 seconds, but vessel is not filling any more, it reached maximum very fast and not filling even if liquid is still flowing. Also, when first vessel is turned and liquid pass to the other vessel, some liquid is disappeared.
On this clip, you can see that liquid is coming from nowhere after the source is stopped.
Please help, I tried so many options but I just cant make some very simple liquid animations.
Thanks.
Mladen Šašić
3D department
Wiltehnik d.o.o. Sarajevo
Thanks.
Mladen Šašić
3D department
