Initial fill up problem
  • Initial fill up problem
    I have a small problem currently I'm trying to use the initial fill up method explained here: http://www.spot3d.com/phoenix20/tips.htm
    Whenever I follow the instruction the object won't emit any fluid at all. Except when I'm removing it from the exclude list but than it will only emit from the sides.
    When I'm opening the example scene beer and follow the steps I don't have any problem at all. It works flawlessly. Saving and loading the beer presets in a new scene won't do the trick either.
    I'm currently at a loss and have no idea whats wrong.
    *edit* Just did a new scene and tried it again from scratch. And this time it worked but after I moved the "brush" object a lil bit it stopped working again.
    Cheers,
    Oliver
    https://www.artstation.com/mokiki
    no idea why, can i see the scene?
    ______________________________________________
    VRScans developer
      It seems I fixed the problem by reinstalling phoenix.
      Cheers,
      Oliver
        ok, if it happens again, please tell us, it's very strange that a reinstall can fix such a problem...
        VRScans developer
