Render Fails After Installing Frost Demo
  • Render Fails After Installing Frost Demo
    Anyone else have a similar problem? The file works in Max 2011, where I didn't install the demo.
    Although the preview looks good I have to reopen in a different Max version in order to render the atmosphereics.
      any additional atmospheres in the list? in the most cases, the different atmospheres are disturbing each other
      ______________________________________________
      VRScans developer
        No, no other...This even happens with the fine smoke sample
          well, definitively should check this
          VRScans developer
            Don't know if this relates, but I often cannot select the component of the simulator from the foam component. I click the box, hit 'h" and select the sim, but no dropdown is visible. GTX560, Windows 7 64 bit and Max 2012 without SP1.
