Hi guys,
I try something that seems to be very easy but doesn't work as I expected.
We do have an object, let's say an oiltank. What I try to do is to fill this tank (btw. from the bottom) and after filling it I'm trying to empty this oiltank (through the same opening).
I tried different options but I don't get it to work. Inside the opening is the source object with a positive discharge. To empty the tank I tried a negative value for this parameter,
I also tried to move the source outside the grid (which leads to a complete filling of the tank?!) and some other things but I don't have a solution for this.
By the way I am using PhoenixFD 1.2.
Thank you,
Fabian
Thank you,
Fabian
