Hi, I am Sungmin Hong, effector from Locus.
I am currently trying to use curve as a force to make pheonix fluid simulation flow along it.
I thought force field will do the trick. So I connected curve's worldspace channel to force field's input curve channel.
As soon as I did that force icon figure immidiatly changes into the shape of curve, which I tried to connect with. I thought it might gonna work for sure.
But it seems like it's not doing the job that I was thinking of, instead driving fluid simulation really weird. If I may try to describe, basically no action at all.
Even the normal fluid simulation without any force isn't working at all.
So here's the question,
1. Is force field meant to be use as a force for fluid simulation? or is it for the particles that is emitted from Pheonix FD itself?
2. If force field is for fluid simulation, what are the things that I have done wrong above?
3. If force field wasn't meant to be used as a force for fluid, is there anyway in Maya to make Pheonix fluid flow along curves??
