Frost Connection?
  • Frost Connection?
    Trying to use Frost to complement a cascade solution. The first simulation is fine, but I cannot find a way to connect the second, cascaded simulation. Also hope there is a way to use Frost on the Foam. Frost complains that no position is given for the Foam. Is there a way to connect Frost with the Foam even though it is not a particle? How does Frost read Phoenix when it is not particle based?
    Phoenix Foam and Splash are particle systems, perhaps Frost can't read them, we have to try this.
    ______________________________________________
    VRScans developer
      If the different elements of Phoenix allowed prt export this would enhance post sculpting of the flows.
