PRT loader workflow
  • PRT loader workflow
    are there any docs to explain the workflow for the PRT loader?
    I'm taking PRT files from Brekel Kinect Point Cloud, into the loader, then using the loader in the PHX Source - is that correct?
    I can't seem to get any results from it, but just trying to figure out if what Brekel is outputting is enough (previously I've been loading them in via frost, then using that as a source for Phoenix) - see results in the image gallery.
    Thanks,
    Steve
    the PRT loader just makes the content of a prt file visible to Phoenix. You can use it as source, or to render it as foam, up to you. Keep in mind that the PRT loader is frame sensitivem it looks for a number at the end of the filename and loads it in the frame that corresponds to the number.
    VRScans developer
      hmm - still can't get it to work.
      I've uploaded the file here - (or will be in an hour)
      https://dl.dropboxusercontent.com/u/...rticle_PRT.rar
      Not sure if you could take a look, see if you can get it to work - it could be the Brekel format is a slightly different flavour that causes problems?
      Regards,
      Steve
