Sphere emitting particles -> enters the grid - instant crash
  • Sphere emitting particles -> enters the grid - instant crash
    Hi
    I have a quite basic setup where I have a sphere that is emitting small amount of particles. Both are selected as source.
    When particles enters the grid, Max will crash instantly.
    phoenixFD_adv_21010_max2012_vray_24_x64
    Ink.zip
    Lasse Kilpia
    VFX Artist
    Post Control Helsinki
    I don't get the crash, but the simulation process stops after the 5th frame.
    It seems that the Noise modifier added to the Sphere is the reason for that, but I will do more testing before i make a more concrete conclusion.
    Edit: are you able to make a complete simulation if you add an additional Edit poly modifier at the top of the GeoSphere001 list?
    Tashko Zashev | chaos.com
      Thanks.
      If I don't have particles, but only the sphere with noise modifier, everything works fine.
      So that's why I thought it could be the problem with the particles. Let's see.
      Lasse Kilpia
      VFX Artist
        Yes. I collapsed the sphere to editable mesh and now everything works just fine with the particles. Weird.
        Lasse Kilpia
        VFX Artist
          yes, as the investigation shows, the particle system is to blame, but nevertheless you can use the edit poly workaround until the fix
          VRScans developer
            I had crashes, where spheres deformed with noise modifer + FFD. Always crashed on sim start right after I restarted max. Then I collapsed - everything worked ok.
            CG Artist
              Alrighty guys, check the latest nightly for the fix
                Well that was fast! Thanks.
                Lasse Kilpia
                VFX Artist
