Mesher wont update from starting frame when rendered
  • Mesher wont update from starting frame when rendered
    I am using a mesher linked to my liquid simulation but the mesher wont update from starting frame when rendered.
    Nathan Evans
    nate@arcfx.com
    www.arcfx.com
    see the input panel, there is a check box called "anim index". by default this option is off, but i suppose you accidentally have turned it on, arn't you?
    VRScans developer
      No, it's off. I've used anim index (which I like) . I was using a mesher because I couldn't apply modifiers to the Phoenix sim box with out issues. If I apply modifiers to the Pheonix sim box "like a turbosmooth, bend, vray displace, etc" it cause the scene to crash when I reopening it. But, I found a work around; the work around I have i to set the modifier to be enabled in render only and not view port.
      Nathan Evans
      nate@arcfx.com
      www.arcfx.com
        the modifier bug is already fixed, which version you have?
        VRScans developer
          Version 2.2
          Nathan Evans
          nate@arcfx.com
          www.arcfx.com
            do you have nightly build access?
            VRScans developer
              Yes, do you recommend a specific version?
              Nathan Evans
              nate@arcfx.com
              www.arcfx.com
                just the last one, the modifier bug was fxed on 1 october
                VRScans developer
