Thanks a lot for all your effort! Unfortunately my result is not the way you described. Yes, it behaves differently, it is right there without settling time and I had to lower the viscosity now to get it even out of the glass. But now I have cells stuck in the wall of the glass and the volume problem persists (see attached previews). Don't get me wrong here, your support is absolutely great (!!), but the hunt for the right combination of system units/SPF/gravity/viscosity is becoming rather tedious, since every value can change everything, and the deadline approaches menacingly.
What would you consider as a high SPF value to get it over with?
And thanks for the hint on the velocity checkbox, I forgot to check that.
