Ram Problem
  • Ram Problem
    Hi, I have a problem which I haven´t encountered before.
    I have one shot that renders just fine up to a certain frame and after that I´m getting errors in the farm: Some nodes don´t render it anymore, and those that do, render the fluids black.
    If I´m rendering locally I can see the ram usage spike very quickly during the "Building static raycast accelerator" stage, so I´m guessing it´s a Ram problem. I don´t understand why it´s only happening after a certain amount of frames (towards the end) though.
    Skyline subdivisions are at 4, meshsmooth is also at 4.
    The resolution is quite big because of the stereoscopy (4440 x 1080), maybe this causes the problem?
    In that case it might help if I split the stereo images instead of rendering it in one pass.
    By the way - do I still need to set default geometry to static or did that change after the official release? Because as I´m watching the render right now, the "Building static raycast accelerator" phase is at 18 minutes and not finshed yet...Changing default geometry didn´t seem to have any effect, so is there anything else I could do to reduce ramload?
      I tried lowering skyline subdivisions and meshsmooth both to 2 and it seems to render now...
        Nope- still the same result: some nodes render, some don´t...
          yes, yesterday another user reported very high ram usage during ocean rendering, i bet it's related to the changes that we introduced last week, apparently in some cases very high triangle count is generated.
          this is a bug for sure, because by idea the changes decrease the triangle count, and in the test here it was exactly as planned.
          ______________________________________________
          VRScans developer
            Oh, alright then, thats unfortunate, but good to hear, because I was already thinking about doing a resim and hoping the issue would be gone then. So I´ll just wait on an update from you guys then, I still got some time to render. If it turns out to be a bigger problem, i´ll just resort to using Cap mode with vraydisplacement ocean and blend it in post.
              You can also use an older build from 17.
              V-Ray/PhoenixFD for Maya developer
                Ok, in case I can´t fix it otherwise I will revert to that build.
                  Hi there, is there any news on the ram issue?
                  Because I ran into the same problem with another scene and that one is less easy to fix with Vraydisplacement and blending...
                  I already checked nightlies and I didn´t find a build from the 17th, there is one from 18th and one from 15th, which one should I revert to?
                    The older one, from 15th. Can you test with it and repord back if the scene renders fine with it?
                      it would be very helpful to send us the scene and the cache file that produces the problem, i hope we will be able to fix it in short time.
                      no need to send the full production scene, just the simulator and the camera, can remove the geometry
                      VRScans developer
                        I´ll strip the scene and send it to support. I might have to send the cache file via wetransfer because it´s around 80 MB.
                          ok, thanks!
                          VRScans developer
                            ok, the bug is fixed, try with the tomorrows build
                            VRScans developer
                            • #15
                              Ah, that´s great, right in time for the weekend render marathon!
