dr rendering black where mesher is.
  • dr rendering black where mesher is.
    I use nightly phoenixFD_adv_21010_max2014_vray_30_x64_24350 and DR is rendering black where the simulator is. It works woth other geo. My path are unc and it render fine on thwe farm without dr.
    transfer missing assets is checked. I tried by removing all the $(simoutput) and inputing the real unc path but it didn't work neither. I removed all my server and readded them and not working neither.
    __________________________________________
    www.strob.net
    Explosion & smoke I did with PhoenixFD
    Little Antman
    See Iron Baby and other of my models on Turbosquid!
    Some RnD involving PhoenixFD
    are the buckets rendered on the client machine also black?
    ______________________________________________
    VRScans developer
      No, the buckets on my workstation render correctly.
      www.strob.net
      Little Antman
        can you send us the log file of some render slave? it is placed in documents/phoenix fd
        VRScans developer
          Installed VRay 30002
          Windows ver: 6 S
          max ver: 16
          target renderer: VRay 3.x
          platform: 64
          revision:24350
          post load - file version 6 created with revision 24350
          Pre render-------------------------------------- Pre render
          frame loaded \\SASORI\PhoeniFDcache\subEauSplash\resimB\subeauS plashResimB, 0
          reinit decompressor threads 0->3
          frame loaded \\SASORI\PhoeniFDcache\subEauSplash\resimB\subeauS plashResimB, 7200
          surflevel[0]=0.5
          interfaces: Sp:0 pg:0 pobjx:4905e268
          Post render--------------------------------------Post render
          frame loaded \\SASORI\PhoeniFDcache\subEauSplash\resimB\subeauS plashResimB, 9600
          surflevel[0]=0.5
          and another one on the same slave:
          Installed VRay 30001
          Windows ver: 6 S
          max ver: 15
          platform: 64
          www.strob.net
          Little Antman
            apparently the path is not a problem, the simulation is visible.
            do you have the same problem when not resiulation, but an ordinary simulation is rendered?
            VRScans developer
