I am trying to reproduce this tutorial from Thinkbox: http://www.thinkboxsoftware.com/stk-...ng-fumefx-sim/
Except I want to do it with phoenixFD instead of fumeFX.
the first step works great. I can use the stoke custom field to influence my phoenixFD sim. You can see the sine wave pattern in this image:
But the next step is to export the velocity from the stoke field in f3d format and load it in a first phoenixFD sim and then use that sim to set the velocity of a second phoenix sim. Tha way the second sim should follow the sine wave more exactly.
But that step does not work. When I try to import the f3d cache sequence in the input of the first phoenixFD, I don't see anything in the list of imported channels. I should see the velocity from the sine wave in stoke.
I notice that it doesn't work neither in my version of fumeFX 2.1c. So I guess it was added specifically in fumeFX int v. 3.
Do you think you could allow phoenixFD to import f3d or vdb fields from stoke?
