Two kinds of problems about redering.
  • Two kinds of problems about redering.
    I found The phoenix fd liquid error problem When I use maya2015.
    There are two kinds of problems about redering.
    If the render mode chaned to solid geometry, Render doesn't work except when set another mesh.
    and also, Set render gizmo mode, If I selecet Object that used as gizmo and simulator.
    These all problems work without any problems in maya 2013.
    Thank you. Please reply.
ID:	880934Click image for larger version
ID:	880936Click image for larger version
    Can you send a scene to phoenix at chaosgroup.com? I think it's not related to the Maya version, but probably to the V-Ray version.
      Beer_test.zip
      Attachments.
        I've just run a quick test and I can confirm that everything worked correctly.
        Would you please let us know which are the exact versions/revision numbers(if nightly builds are installed) of V-Ray and Phoenix FD?
        Thank you very much in advance.
