Hello, I was working on trying to setup a tank shooting + dust based on some interesting posts I found on youtube, and I'm finding that phoenix is timing out or simply crashing after about 10-20 frames. If I check my RAM it's not capped out or anything, but for some reason I just can't get this simulation to go. It works if I reduce the res or lower the quality, but according to the tut this was the setting used. I was mainly doing it for a comparison.
Tried to figure it out but I don't know where the problem lies. I'm not overly concerned about the time per frame, but the crashing is making it moot. I'm certain I did something wrong in here, but I'm not sure what. I've attached the scene, it's very simple just a test really. I've tried everything from remaking the entire scene to using the max memory %, but nothing is helping. (Sim says it only needs 4GB ram and I have 32). Again, I'm sure I did something wrong but I can't figure out what it might be that causes it to choke. Any help is greatly appreciated.
Tank Phoenix.zip
Tank Phoenix.zip
