can you share images? the latest foam tests here look good, even the foam can be made to overflow the glass and to leak slowly down (with the sticky option)
Beer with flip
actually the high b2b makes the foam harder, so it does the opposite of your needs
how old is your build? the latest days some polishing was done in order to remove residual movement of the bubbles and to get stable sticky behavior. the foam is really harder compared to the old core, but the real beer foam also gets similar forms. our goal is to make all levels of hardness possible with only one parameter (b2b)______________________________________________
VRScans developer
Wtf... I reinstalled Max but it´s still crashing on start without an specific errormessage. Before the reinstall it called some error with a physx.dlm file or something. Is there an easy solution on this?? Im not a big fan of AutodeskAnd not an technical expert.
It´s not your problem, I know, but maybe you´ve been in same situation before??
yes, i have been, that's why i'm very conservative user and update the software only with very serious reason. of course as developer i'm pushing the users to update phoenix, a kind of hypocrisy
perhaps the photoshop has replaced some dlls shared with max, who knows.______________________________________________
VRScans developer
Originally posted by Magnum_design View PostI reinstalled vray and removed the files that was left, then installed the latest Phoenix nightly. Back on track again
Originally posted by Ivaylo Katev View Postyes, i have been, that's why i'm very conservative user and update the software only with very serious reason. of course as developer i'm pushing the users to update phoenix, a kind of hypocrisy
