Coordination with Krakatoa
  • Coordination with Krakatoa
    Used particle flow Phoenix Birth and Phoenix Force. Flow looks good in the viewport, but Krakatoa range render keeps putting out the same frame over and over again.
    Have to use the prt loader
      is it solved already?
      btw, we added the drag particles exactly with the idea to avoid the particle flow that is unacceptable slower. of course if you need complex particle behavior you must use particle flow, but just for rendering smoke there is no reason to use it.
      VRScans developer
        Great, so no more slow pf. Also Krakatoa renders the Phoenix sim at the same time.
          the drag particles are very very old feature. this video is using them, if i'm not wrong.
          VRScans developer
