Phoenix - "Vray Exception" Error Message - Possibly causes by Foam and splash shader
  • Phoenix - "Vray Exception" Error Message - Possibly causes by Foam and splash shader
    I got a error message when I try to render my scene with vray and phoenix. It render fine, but the error message prompt at the end of the rendering process of each frame so I can't render my animation.
    It seems that this is de Foam and Splash shader that cause the error because when I deleted it it render fine without error message.
    I got the vrayLog file at the link below.
    https://www.dropbox.com/s/jzphxqinlt...aylog.txt?dl=0
    Thanks
    Hello,
    Try the workaround from this thread:
    http://forums.chaosgroup.com/showthr...-particle-flow
