Phoenix Force Field
  • Phoenix Force Field
    Hi
    I am trying to get Maya Nparticles driven by Phoenix simulation
    using Force field. I noticed the initial velocity and the speed of the particles gets
    reduced drastically, even though the conserve parameter of Nparticles is kept at 1.
    Is this a usual phenomenon?
    Kishore Guntuku, Cine-Chromatix KG. Berlin
    Did you check the phx_emitter.ma example? There are some other parameters like influence, and distance fall off. Not sure what is the problem without the actual scene.
    V-Ray/PhoenixFD for Maya developer
