crash in foam point mode
  • crash in foam point mode
    it worked in a simple test scene in splahes mode so i presumed it was resolved and not only working in point mode anymore. now in my project scene it started crashing, so i changed to point mode, figuring it would at least still work in that mode. also getting a crash, so can't use foam qty multiplier at all now. i'm using the latest build as of a couple nights ago.
    in a fresh simple test scene, it's working again - unfortunately can't rebuild this production scene from scratch at this point. any recent history of crashes with foam qty multiplier greater than 1.0 and a solution without starting over?
      can you attach the log file after crashing?
      ______________________________________________
      VRScans developer
        sure thing Ivaylo. where would I find that file?
          Hey,
          It usually resides in C:\PhoenixFD - you gotta copy it right after the crash occurs, otherwise if you run 3ds max again, it will be overwritten.
          Cheers!
            got it. alright - i'll try to reproduce it. thanks!
