PHXFoam and Pflow unknown exception
  • PHXFoam and Pflow unknown exception
    just found out that if i have in the scene PHXFoam and pflow (even if the pflow is not connected to the PHXFoam) max through "Unexpected exception"
    you can test it by creating a PHXFoam object, create a Preset Flow in Pflow and thn hit render.
    the error will pop up.
    Works fine here, my version of phoenix is from late March I think.
    Adam Trowers
      Seems to be working here as well. What build are you using? Do you render with V-Ray(which version) or Scanline?
      Georgi Zhekov
      Phoenix Product Manager
      Chaos
        my version is from 20.4.16 and before that i've tested this with 11.4.16.
        this problem is happening both with VRay 3 and with scanline
          also i should add that i'm using 3Ds Max 2014 and windows 7
            It would be better if you could attach the scene you are working on so we could investigate what's going on.
              sure thing.
              here is a link to download the scene:
              https://we.tl/6jlfgkwsQ8
                Very strange, couldn't blow it up on several different machines.
                Would you be able to post here the phoenix_maxver2014.log file you can find on your C:\PhoenixFD immediately after the crash?
                  sure:
                    Hey,
                    I think I have an idea of what's going on - in your scene, in the environment and effects dialogue there should be a couple of atmospheres - one of them is PhoenixFD, and the other one is the V-Ray VoulmeGrid's atmosphere. If you delete the volume grid, it should be okay. We fixed this a while back in both Phoenix and V-Ray. Which V-Ray version do you use? In 3.30 it should be okay.
                      oh!
                      we are using in the studio VRay ver 3.20.02.
                      i have noticed the VolumeGrid Atmosphere. but every time that i delete it, it is automatically being added back
                        Yup, that was fixed too - now the volume grid atmos shouldn't be created for no reason.
                          great. thank you very much for your help
