PHX foam stating that PA and Velocity are missing when they are not...
  • PHX foam stating that PA and Velocity are missing when they are not...
    If i skip one frame, the PHXliquid is stating that the channels exist but if I press render I get warnings from the PHXfoam and it switches off motionBlur and PA...
    the simulation take a day and can't be sure it will work since it should work...
    in a HURRY !!!!
    the PHX itself is not giving any warning...
    Hey,
    Yes, there's an issue with the Simulation panel showing particle counts while the actual particle data is not present.
    Please check your Output panel - there is a Particles section there - when you switch the combo to Foam or Splash, do you have the velocity and particle age channels checked? If you don't, you'll have to simulate again.
    Cheers!
      I have.
      does it do the camera motion blur anyway?
        ok, my mistake, i didn't know you need to check IN the list...
          f##k, I am doomed to resimulate...
