Hi guys and girls,
I'm having a problem getting the same results as this flamethrower tutorial on the ChaosGroup page.
Link: https://www.youtube.com/watch?v=LY8cL9caGRg
Things you should know:
01. I'm using the latest nightly for 3ds max 2017 (I have also tested it in 2016 with no success)
02. units are setup the same as in the video, in cm for both the display units and the system units.
I must have followed the tutorial about 5 or 6 times now from start to finish to make sure I did not miss anything, but I get nowhere near the same results. I don't know if this method is old and if there is a better way of doing it, but that is why I'm posting it here.
Several differences I noticed between the nightly and the version Tsvetan is using in the tutorial video.
01. Massive Vorticity is not there so I disabled it and used Classic Vorticity (tried both, neither worked.)
02. Conservation method is called Direct Symmetric, whereas in his video it's just called symmetric (I tried all of the methods, none worked.)
03. In the Pheonix source there is no checkbox for "use particle size" but there is an option called use particle shape (I tried all the options in this drop-down box, only two of them actually simulated anything, but alas none of them worked.)
Also note that he changes the values throughout the video so the values that I have in the file I have attached are from the last part of the video. Throughout the video my simulation never looked like his.
I'm really stumped and this is for a live job that I need to get a similar results for.
Here: http://image.slidesharecdn.com/1-1in...?cb=1355391074
I'm sorry for the long message but any help would be greatly appreciated.
Phoenix FD Nightly problem.zip
