Fire suddenly goes off to the right
  • Fire suddenly goes off to the right
    I have a simple setup where an object falls down over 500 frames that is on fire. On around frame 380 the object passes a "magic border" and the fire that was rising / trailing behind the object, suddenly goes off to the right, like there was a massive windforce hitting it suddenly. (think rocket enginge.) You can actually see the border clearly in the simulation. What could be the problem? I only have one wind force in the sim, and that has zero on wind and 100 on turb. Looks like a bug, but I will try it again and delete everything that is not needed for the sim and see if that helps.
    I still use 2.2, could it be an old bug? I tried to install one of the latest nightlies on a similar scene, but all kinds of wierd things happened, so I reverted back again. (the emission object was emitting in two places at the same time among other things)
    Any clues? Is there a floor setting I have missed?
    Can you give us the scene or a simplified version if it's confidential so we can take a look?
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Thank you for you quick reply. I think I have found what is causing the issue. It seems that object velocity was set to one, and my alembic files gets a super extreme reaction to it's movements. (this is what I suspect anyway.) So now I am running it again with 0 velocity and with fingers crossed, it might work.
      I would like to send you guys the file anyway so you can see the issues. I'm not so savvy in Max, is there a function that gathers all assets into the file to make it easy to ship off? (alembics, textures and so on.)
      Thanks
      M
        You can save the scene as an archive and Max should pack everything into it (File > Save as > Archive)
        Miroslav Ivanov
        Chaos Cosmos
          oh, cool! I will do that. I have already sent the scene and assets off to support, but it will probably be a lot easier to make the scene work for you guys this way, so I will upload that too.
