Rendering to Backburner issues
  • Rendering to Backburner issues
    hey gang,
    im having an issue when i send my sim to backburner. i believe that the volumetric render settings might be getting set back to default. im not sure why or how this is happening.
    any help would be appreciated.
    Cheers,
Name:	Local Machine.jpg
    Hey,
    Could you share shots of your volumetric render settings? Are you absolutely sure that you have the same versions of Phoenix and V-Ray on your local and remote machine?
    Cheers!
      thanks for the reply.
      yes they are the same version.
        Ah, you are using a version that had this exact same bug with resetting the render settings that lasted for a couple of days - it's fixed in the nightly of 27 April. Cheers!
          awesome i"m glad you know what the issue is. could you send me a link to that exact nightly or the most current one?
            If you have nightly access - you should be able to see all the nightly builds. If you don't you can write to support@chaosgroup.com and they will figure it out.
            Georgi Zhekov
            Phoenix Product Manager
            Chaos
