I am trying to do a missile trail but the smoke is being emited with an offset from the emiter position. do you have any idea what can cause this? I simulated 2 times to be sure I didn't move the box accidentally. It is offseted from the first to the last frame of the simulation. I have to offset it back into place before rendering.
One thing to note is that i put the z axis of the grid in the direction the missile is moving so I can animate it by hand since the adpative grid system is not working.
edit: I am doing some tests and i can see it happens when I animate the size of the grid... If I don't animate it there is no offset.
