Hi, I have purchased a Phoenix FD 3.0 workstation and separate simulation license for 3DsMax 2014 SP5 (Default Scanline) for Windows 7 64BIT SP1.
I am having trouble getting my simulation node to start simulating when I submit a job to Backburner. I can see through the license webpage that one of the simulation licenses is being checked out by the node and the other by my workstation, however the node just hangs forever with the max render dialog saying '99 of 99 frames' and a blank render window. It does not produce any .aur frames. I have tried pathing my output to a local directory, UNC shared network directory and using 'browse to folder'.
I have tried running Backburner locally and submitting jobs to localhost, but the result is the same. I have also tried starting a simulation job using cmd and Muster render manager.
I have Vray 2.5 installed, however I am just using the Default Scanline installation of Phoenix as it is only compatible with VRay 3.0. I have tried uninstalling VRay, but that didn't help. I am also running the latest license server.
I would really appreciate some guidance from someone who has this up and running. I must be missing something.
Cheers,
Dan.
Cheers,
Dan.
