Resimulate Foam
  • Resimulate Foam
    i have a problem with the foam generation. First i did a simulation where a car is falling into a lake.
    As second part i want to do a resimaulation for splashes and foam. The splashes are doing well.
    But the foamsim crashes 3ds max. The Foam amount is already set to 0,001. Phoenix is generating to much
    foam particles but i can get under 0,001, next smaller is 0.
    You can increase your velocity threshold and that should do the job.
    Still 3dsmax shoudn't crash when you have too much foam. What version of Phoenix are you using?
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Ok thanks, i will try that. I am using 3.00.02 in 3ds max 2017.
        Can you send a crashing scene to support@chaosgroup.com so we can take a look?
        Thank you,
        Georgi Zhekov
        Chaos
          Hi, i sent the file to the support address.
