nightlies install problems
  • nightlies install problems
    I have tried to install the two latest nightlies. (scanline 2016.) But after the installation, max retuns an error on startup that it cannot find the module, and now nothing works!!??!!
    heeelp!
    getting the same error with 2017...
      What is the error you are getting?
      Georgi Zhekov
      Phoenix Product Manager
      Chaos
        When I start max I get this popup, and the plugin is gone.
          There seems to be an issue with the nightly Scanline installations - you can try with a nightly from 18.02.2017 and it should work.
          Georgi Zhekov
          Chaos
            ok, thanks
              Hey, this is fixed in today's nightlies. Thanks very much for reporting it!
                Great! I will check it out.
