Problem with animated object, particles do not follow the animation of the object
  • Problem with animated object, particles do not follow the animation of the object
    As you can see in this scene, the particles do not fill the object that is in motion, it is like the object is cutting the stream of particles instead of containing them.. what am I missing here?
    Hey, there was a bug in 3.03 where moving geometry could kill a lot of particles when it pushes them. Grab a latest nightly and check how it works for you.
      could you remind me how to get the nightly builds? I have not done it in a long time and I dont have the links to it.
      Thanks
        if there is a bug on this build, then why the wine bottle example works fine?
          does the attached scene works fine for you?
            Yup - it seems to work fine on my end. The nightlies are at nightlies.chaosgroup.com. If you don't see Phoenix 3 there, drop a mail to Support at chaosgroup dot com with your user name and they will give you permissions.
