Restore Frames Foam Not Rendering
  • Restore Frames Foam Not Rendering
    I had an issue today where foam wouldn't render on restore frames. The splash didn't have this issue though. I'm going to try simming without restore frames because this is just a test but I was curious if anyone else had this issue.
    [UPDATE] Just to try something; I included liquid particles, grid velocity, and foam velocity into the output but it still wouldn't render on restore frames. I removed any restore frames and now it works (but that could be an issue in production).
    Josh Clos
    FX / 3D Generalist
    Huh, not cool. Are you on a nightly build? Any chance we could reproduce it here or if you can send over the scene and one bad cache?
      I'm currently at a studio that doesn't roll out nightly builds so I'm on 3.03 here. Sadly, I also am unable to get the scene off of this computer (due to NDAs) but I'll re-create the same setup at home and see if the issue happens - if it does, I'll upload the file from there. If the nightly build fixes it, I'll let em know and hopefully they'll pick it up.
      Appreciate your help!
      Josh Clos
      FX / 3D Generalist
        Thanks very much! It's important to catch this...
