I'm in 3.03 and I have a sim of a boat slowly traveling with a moving container and if I set the mesh mode to "Mesh," I can see the foam trail that goes beyond the container but once set to Ocean Mesh, even without displacement, it cuts off the foam at the end of the container.
[UPDATE] I sort of figured this out. It looks like the foam outside the container lowers its position once it travels beyond the container so the ocean level was covering the outside foam. So if I lower the ocean level, I can now see the foam but the ocean level is lower than I'd like. The sim is pretty low res at about 2,000,000 grid and I've found this "lowering" of particles outside the grid is less at higher resolutions. This should work for now - I'll test more at home.
