Permanently disable no voxels in the volumetric completely transparent message
  • Permanently disable no voxels in the volumetric completely transparent message
    Hi Anyway to forever disable this message "no voxels in the volumetric completely transparent message "
    we use octane and it does not effect us but this message stops the rendering. If we click do not display next time it will still do it if 3ds max is restarted or a new grid is created. It would just stop our rendering. Plus there are voxels there is a fuel that is coming out that is about to catch on fire. thanks
    Hey,
    "Do not show" is saved to the max file, so you need to save the scene after you select it.
    Eventually we could add an option to the Phoenix preferences that will turn off all warnings for this version of Max/Maya.
      Originally posted by Svetlin.Nikolov View Post
      Hey,
      thanks. Not sure how voxels are clear
        Um, sorry, can you elaborate more on this?
          Hi. It is showing smoke and fire but we get a warning message voxels are clear. Does it mean something else I guess?
            Can you screenshot your Fire and Smoke Opacity render settings?
              Hi I will try. We are using Octane to render. It would be nice to have this message disabled. last night rendering stopped because this message came up. I know you can click do not show the message but we don't know at what frame it will come up. Thank you
