Foam offset
  • Foam offset
    Not sure if there is a foam offset but would be good to be able to lower the foam a little as the reflection on the water surface creates a doubling up effect with the foam sat a bit above the surface.. if there is an option I have missed then apologies :P
    ** Just seen it was raised in this thread: https://forums.chaosgroup.com/forum/...surface-offset
    Dropbox is a free service that lets you bring your photos, docs, and videos anywhere and share them easily. Never email yourself a file again!
    Adam Trowers
    Hey! But with your scenario, is there smoothing as well?
      No, no smoothing and it is not using the particles etc just a basic ocean mesh
      Adam Trowers
        Weird thing... Will add an option to offset the particle data.
          An update - in tomorrow's nightly there will be a crude option for offsetting particles vertically...
            Awesome.. thanks Svetlin, this will especially work well with low res sims when the foam generally sits quite high
            Adam Trowers
              Hope it helps a bit this way - determining how much the mesh vertices changed during smoothing and applying this back to the particles would be a difficult task, much like applying the displacement over the particles, where you'd want to do this only for the particles close to the mesh, so I still have to think about it. Alternatively it could be an algorithm that shifts all particles a certain distance towards the closest geometry, but this might look bad in animation.
                this parameter is available in the latest nightly build. You can find it named as Vertical Offset in the particle shader.
