blank frames after frame #64
  • blank frames after frame #64
    Max start 2017.08.23 00:41
    Installed V-Ray 32501
    Windows ver: 6
    3ds max ver: 18
    Target renderer: V-Ray 3.60.03
    Platform: 64
    Build ID:170302
    Memory info: total: 63,938GB, free: 59,203GB
    Simulated with v3.03.00 (rev.170302) for 3ds Max 2016 from Mar 2 2017
    Any special reason why Vray would stop rendering Phoenix fire and scene geo?
    I have rebooted the pc and its the same problem. Sim looks ok in viewport. 0-118 frames size of the sim file is about 26 Mb at frame 65. i bare use any mamory while rendering. Scene is just boxes + sim.
    It does the self-illumination calculation and buckets fly by but result is black.
    I have updated Phoenix to v.3.04.00
    Any tip on where I should look?
    If geometry disappears too it's something with V-Ray or within your scene settings. My suggestion is to make another simplified scene and try a fast simulation and then render the result. If the problem still exists, please send us a scene to check what's gone wrong.
      I made a simple scene and everything worked. I also recreated the sim and all is fine. Not sure what went wrong. But I can't reproduce it.
