We're running PhoenixFD version 3.04.00 with the mayapy.exe from Maya 2016.5 on WIndows 7 x64 and encountering a crash. We enabled MAYA_DEBUG_ENABLE_CRASH_REPORTING and the crash is inside the PhoenixFD plug-in. Here is the information from the crash file generated when mayapy.exe terminates:
Maya Crash Report
Exception code: C0000094: INT_DIVIDE_BY_ZERO
Fault address: B2B4C8BF in C:\Program Files\Autodesk\Maya2016.5\phoenixfd\plug-ins\phoenixfd.mll
0001:0027B8BF Logical offset (see .map file for location)
Call stack:
(11) section
ffset 0001:0027B8BF Address: 0xB2B4C8BF Frame: 0x0023C310
Module: C:\Program Files\Autodesk\Maya2016.5\phoenixfd\plug-ins\phoenixfd.mll (-exported-)
Source: (0)
(12) section
ffset 0001:00172AD0 Address: 0xB2A43AD0 Frame: 0x0023C850
Source: (0)
(13) section
ffset 0001:0013E71B Address: 0xC06BF71B Frame: 0x0023C8B0
Module: C:\Program Files\Autodesk\Maya2016.5\bin\OpenMaya.dll (-exported-)
Decl: public: virtual void THsurfaceShape::computePlug(class Tplug const & ptr64,class TdataBlock & ptr64)
Source: (0)
(14) section
ffset 0001:0015E68E Address: 0xCAC4F68E Frame: 0x0023CA40
Module: C:\Program Files\Autodesk\Maya2016.5\bin\DependEngine.dll (-exported-)
Decl: protected: virtual bool TdependNode::dbEvaluate(class TmsgEval & ptr64)
The simulation works interactively, just crashes when run from mayapy.exe which may be a red herring. What we're trying to do is drive the vertices of a polyhedral mesh from a PhoenixFD simulation. I am attaching the entire MayaCrashLog with the stack trace Note that the first 10 stack frames are missing (whatever phoenixfd is calling into).
Has anyone reported a crash like this?
Thanks,
- Bill
Maya Crash Report
Call stack:
(11) section
Source: (0)
(12) section
Source: (0)
(13) section
Source: (0)
(14) section
Thanks,
- Bill
