Gravity & BodyForce
  • Gravity & BodyForce
    Hello,
    I use Bodyforce to keep water in the shape of an animated mesh.
    I setup BodyForce to let some water escaping from the mesh with a really short Max distance.
    The Body force work like expected But i have to setup 0 at gravity dynamics .
    Now i want the escaped particles of water working with gravity .
    But it's all the particles wich are following gravity ... so i setup gravity very low like 0.1 and Bodyforce Strength very high like 50000 , but it make all the particules crazy :/
    there is a way to say, particles inside body mesh are not gravity allowed. others yes or other force ?
    GHiOM = Guillaume Gaillard
    freelance 3D artist
    www.ghiom.com
    Hey, check out these Body Force settings. Also, I set SPF to 10 to calm down the fluid.
    P.S. Not too much Spread Speed could help too.
    You can check and body force settings here:
    https://docs.chaosgroup.com/display/...+%7C+BodyForce
    BodyForceAndGravity_2015.zip
      Thanks you George, i 'll check it
      freelance 3D artist
      www.ghiom.com
