Grid getting visible with High Surface Tension
  • Grid getting visible with High Surface Tension
    I started with a sphere brushed with "Milk", while falling down its shape is influenced by the grid, becoming more and more like a box...
    Any idea how to avoid that?
    Hey,
    Try zeroing the surface tension. In case you have Air Effects on, disable them as well.
    Hope this helps
      not really, it's a just a test for getting familiar with the new surface tension params so no real problem, but it looks like something that needs to be improved...
      I am experimenting on how to simulate micro behaviour of liquids...
        Yup, it's a known issue that surface tension causes such shapes to form and hopefully soon there will be a fix.
        Cheers!
          Finer grid resolution should dimmish the "box" effect.
