Ocean Mesh
  • Ocean Mesh
    i want to use the ocean mesh in Phoenix. But get some ugly seams See screenshots.
    Hey, make sure that you are using the latest Phoenix FD build, then you will need to increase you Ocean subdivs. You have high mesh resolution of the simulator but low ocean resolution and this is why the surfaces differ so much. You need to increase your ocean subdivs parameter until the detail match. This is because currently there is no way to decrease the detail level of the simulator, otherwise if you have splashed liquid in it, it would start losing shape.
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      All right, will try that, thanks.
