I'm trying to test a foot print type effect, but the foot is invisble so you would see the impression of the foot. in my Test here when I lower the geo into the 1/4 filled grid, the first frame of penetration looks good, but immediately after some of the liquid pops into the volumes. Ive tried high grid resolution and also high spf. Same results with both tests. Even tried "clear inside" on the geo and it just made the error look different. Am I missing something? I'm using Maya 2016 and PHX 3.10.00, build ID: 180213
Geo colliding with liquid surface, liquid penetrates through.
Hey,
If your geometry in Solid mode, or is it unchecked (from the Phoenix extra attributes)? Clear Inside should be needed only if the geometry is not solid, and in this case it will not push the fluid, but just erase it, so using just a Solid obstacle geometry should be enough.
Cheers!Svetlin Nikolov, Ex Phoenix team lead
Thanks for the reply. The Geo is set to solid. That is the default setting I believe. And yes I was just trying different things. I got the same result before I tried setting "clear inside".
Tried again with extruded geo so there is an inside face, still getting pretty ugly results. Is it a grid resolution issue?
1 Photo
Ah, thanks! I should have seen it in the screenshots - so the geometries are hollow and the Fillup for Ocean option creates liquid on the inside of them. You just gotta use solid geometries without cavities that go under the ocean level.
If you want to not have to think about that at all with this setup, disable the initial fillup from the simulator, create a box with the size of the ground, and from its Phoenix extra attributes use "Initial Liquid Fill".
