add multyple items to include/exlude list and to add in source
  • add multyple items to include/exlude list and to add in source
    As it happened i need to add 208 objects to a fire source, and to include the same 208 object to an include list.. mi brain and eyes and hand hurt now. I can add only one item at a time. Really need a better way to add items.
    Hey,
    If you press the Add button in the source and then press "H" on the keyboard it will prompt you with the Max selection window, from there just shift-select all of the needed objects and you should be good to go.
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
      Hey, if you are in Maya, you can drop them all at once into the source set.
      If you are in 3ds Max, click 'Add' on the Source, then click Max's "Select by Name", and then shift select all objects you wanna add
Name:	max src select 1.png
Name:	max src select 2.png
        Boom, same time
          that was great! saved me lots of trouble. But it is missable. So the wish remains a button to add from a list or from selection for example.
