Export Wetmap as image sequence?
  • Export Wetmap as image sequence?
    Is it possible to render/export the wetmap as an image sequence? I am unable to get the PhoenixFDParticleTex to render with NEXT GPU. Realflow for example renders out an image sequence which can then be loaded in as a map.
    Hey,
    This is still in the to do list I'm afraid. Adding one more vote for it.
    You could probably bake it by attaching the texture to a plane and render this out using V-Ray CPU and then load it as a texture.
    Georgi Zhekov
    Phoenix Product Manager
    Chaos
