Cache Previewer Minor Request
  • Cache Previewer Minor Request
    It would be way cool if there was a button in the Previewer to let you copy the cache filename (ideally one to copy the filename, and one to copy the entire path-- or alt-click to copy the entire path or whatever-- the path is actually more important than the filename because it can be pasted into a node to load it in.).
    Thanks.
    Yess, sounds like a 10 minute thing and there also are a couple more things I need to change in the previewer while I'm in the area....
      You’re the best.
        Aaaaand it will be in tomorrow's nightlies
          Awesome! Thanks.
