See numeric value of the channels in preview
  • See numeric value of the channels in preview
    It would be great to see some numeric representation of channel values in the view port (like you can do with fume's slice+numeric values turned on).
    Its good to know what exact temp/smoke values are.
    Jordan Walsh
    Senior FX artist
    Showreel 2010 (new)
    Check out my scripts at Script Spot!
    i agree, the idea is not bad. btw, in the next update the preview control is more detailed - all the channels have upper and lower value, not just a threshold, and also have a color ramp.
    ______________________________________________
    VRScans developer
      dose this mean that the GPU preview will show smoke better? (ie, not flat black!) That would be great!!
      Jordan Walsh
      Senior FX artist
      Showreel 2010 (new)
        While im at it, the display of the Velocity is a bit busy. It would be good to be able to change the length of the preview lines and have them show the magnitude rather than just direction. Also if they were displayed as a single line with a dot or a 'T' at the end or a color gradient to indicate direction it would be cleaner.
        Jordan Walsh
        Senior FX artist
        Showreel 2010 (new)
          thi is sheduled, but not for the next update
          for some mysterious reasons, the lines in the max are drawn extremly slow. the triangles are much faster.
          VRScans developer
            Ok, faster is better!
            Being able to change the scale would be handy though....
            Jordan Walsh
            Senior FX artist
            Showreel 2010 (new)
